I need some help with the homing offset. I’m trying to offset from my gamma max 5mm however when it reaches the switch it just stops and doesn’t offset. I think I might have something mixed up because I’m homing to max and not min. Can anyone shed some light please? Here’s what I’ve got so far:
#gamma_min_endstop 1.28-
gamma_max_endstop 1.29-
gamma_homing_direction home_to_max
gamma_min 0
gamma_max 200
alpha_max_travel 1236
beta_max_travel 700
gamma_max_travel 500
Optional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable false
#beta_limit_enable false
#gamma_limit_enable false
Endstops home at their fast feedrate first, then once the endstop is found they home again at their slow feedrate for accuracy
alpha_fast_homing_rate_mm_s 100
alpha_slow_homing_rate_mm_s 25
beta_fast_homing_rate_mm_s 100
beta_slow_homing_rate_mm_s 25
gamma_fast_homing_rate_mm_s 4
gamma_slow_homing_rate_mm_s 2
alpha_homing_retract_mm 5
beta_homing_retract_mm 5
gamma_homing_retract_mm 5
Seeing the motor info from the setup file couldnt hurt either.
