I read somewhere that there’s some config changes required for deltas with the latest major code merge? Can’t seem to find where I read it. Anyone know about this?
@Shai_Schechter Hey, I think this is what you are looking for : http://smoothieware.org/blog:14
Cheers.
Thanks! Read it and made the .hotend. changes, but regarding inverting the pin for extruder, is that necessary? I didn’t do it and it still works fine…
If it works fine, don’t change it
if the extruder did not reverse then you are not using edge but still using master. If you are using the firmware I sent you then you are on master not edge as you requested.y
and you should not make any of the changes in the blog post if you are on master branch.
Ok thanks for the info @Wolfmanjm . I changed the .hotend. but that was all that was changed. Seems to still work, but I’ll revert it back.
actually the .hotend stuff is valid for master and edge. so yu can leave it as .hotend.
