I recently figured out the issue with RASTER via inkscape exporting plugin thanks to members in this community. It involved comparing their firmware to mine and adjusting variables accordingly. Superposition there were allot of differences between the two even though both were same builds and electronics (ramps 1.4 + arduino). Once I got this all figured out I tested another software I loved using for RASTER during which time inkscape was not working. Here’s the thing this other software wouldn’t work with the same firmware config.h which now allows for RASTER via inkscape, so I went back into config.h and checked code again and the one variable that stood out as a big difference was laser_pwm Hertz variable previously 25000 and now 50000. So I changed it back to 25000 and now both RASTER software programs work!
Now if you follow what I’ve laid out above then here’s my question. Can this pwm Hertz value be set to a variable like ;#define laser_pwm 25000-50000? Or is there a sweet spot for this variable which allows for best results? What does the Hertz do other than control frequency or what does frequency do in regards to end result (laser contact with objects)?
Sorry if this is hard to follow but I am learning as I go and my current understanding of all this is very limited.
