I remembered someone posted a DC-DC convertor chip recently, but I can’t find it back. I though it was @Jon_Burroughs or +Robert Atkins?(pointing to persons in Google+ sucks, why it doesn’t simple point to people in this group).
I’m looking for a DC-DC suggestion that can support 8-9A 5V and supports an input of 12V (or higher). I want to put it on my PCB design.
Oh sorry, I misread and didn’t see you wanted a chip. Yes, you want a buck converter. They all work pretty much the same. The main external parts you’ll need to supply are an inductor and a FET. That TI part you mention looks pretty good. These chips will all be surface-mount. If you’re hand-soldering, try to get something not in QFN or other leadless package. Those can be a pain. You’ll need to make a PCB for it. Doing high-frequency, high-power switching power supplies on a breadboard will not work.
Thanks. I’m now trying to make a surface-mount PCB. I thought the component that was shown here sometime had already some external parts (like a coil what it seems from the picture) build in. The less I have to place on the PCB the better.
I haven’t used either, so please do report back if you try either of those out. I get the sense that switching power supply design is a black art, so if you can use a pre-built module (UL et al certified, probably won’t explode and burn your house down) you probably should.
I’m designing a PCB with APA102 leds, RFDuino and some power supply to bake in a reflow oven (at least the prototypes). I don’t want to solder that many components.
