I saw this on the 3d printer discussion & thought it would be worth a look at here
Originally shared by Christian Ledermann
While most RepRap and 3D printer controller boards use an ATMega or other 8-bit microcontroller, the Smoothie uses a 32-bit ARM chip in the form of an NXP LPC Cortex-M3 chip. Not only does this allow the Smoothie to do some very cool things with your machine – native arcs and circles, for example, but this better hardware also allows for Ethernet, drag-and-drop firmware, and exposing the USB port as both a serial port or mass storage device. http://hackaday.com/2013/09/30/smoothieboard-the-be-all-end-all-cnc-controller/
IMHO, at their asking price it’s getting close to linuxCNC on a Beagle Bone Black territory. Also I’ve seen comments that their lead developer is pretty bad about using other open source code without proper credit to the source (sloppy, not dishonest) which may lead to big problems in the future. Might be best to let this one settle out a bit.
The biggest difference is the tinyG is a 16Mhz 8 bit AVR processor, smoothie is a 96 to 120 MHz 32 bit ARM processor (Kickstarter was a bit vague on quick read).
