I think I just killed my Printrbot  Simple Printrboard connecting the auto-level probe...  It's
I think I just killed my @Printrbot Simple Printrboard connecting the auto-level probe…
It’s not communicating anymore and the extruder fan keeps spinning…
Any hints ?
Just realized what I did wrong… Connected the wrong side of the +Printrboard probe adapter cable to the Printrboard, this bringing +12v to the pin2 of the Z-Stop connector. Pin 2 is +5v… Si just injected +12v on the +5v rail. ouch… It’s definitively toasted…
Now @Printrbot only has RevF on their store and it has a 6 pin power connector. I have a RevD with the 4 pin power connector…
Not true, they have RevD:
http://printrbot.com/shop/printrbot-printrboard/
@Voxel_Factory You have any in stock in Montreal ?
Fwiw, I nuked my arduino mega tonight, too. I suspect a thermal event.
i’m sorry for your loss
I’ve converted all my printrbots to Ramps. Not touching the printrboard again.
Arghhh unable to order a RevD from @Printrbot . Store says there are 2 left but then it says:
“Sorry, we do not have enough “Printrboard Rev D (refurbished)” in stock to fulfill your order right now. Please try again in 60 minutes or edit your cart and try again. We apologise for any inconvenience caused.”
@Brook_Drumm ?
@Andre_Courchesne1 why no Rev F?
@Thomas_Sanladerer well rev F has a 6 pin power connectio and I am wired for the 4 pins. Also didn’t some stepper changed direction on rev F ?
@Andre_Courchesne1 stepper direction is easy to fix: Just flip the motor connector around.
The new power connector is “from the same family”, as @Printrbot puts it, so i’d expect it to be compatible with the older 4-pin one. Either way, printrbot’s printrboard comes with a fresh 6-pin to barrel jack harness.
This sucks, can not even order the rev F from @Printrbot store … Getting the same:
“Sorry, we do not have enough “Printrboard Rev F” in stock to fulfill your order right now. Please try again in 60 minutes or edit your cart and try again. We apologise for any inconvenience caused.”
Even if the store shows there is 1 remaining in stock…
Ok, so was able to order a RevD board. Don’t really see the benefit of the RevF (according to the changelog anyway). And the RevD was 30$ less than the RevF.
It’s already shipped from @Printrbot offices. Can’t wit to put my printer back in working order and finish my Z-Probe install.
