That’s the one I purchased. I run 3S on it. If the speed is a bit much, depending on your transmitter, you should be able to dial back the top end to reduce the speed (max servo throw). (This will not however reduce the torque / power dumping into the motor and drive train components on start [if you have issues with things braking].)
