I thought this post by Wayne Friedt   would add value to the 3D
I thought this post by @Wayne_Friedt would add value to the 3D Printing Group. You may also be able to chip in with more info/advice.
Originally shared by Wayne Friedt
Is an stl file universal. Can the stl file be opened by most any cad program that works with stl’s or that can export stl’s?
Example: a file from Openscad export to an stl. Then i try to reopen that stl file in Autocad2013, 123D Design but says file is not supported. Seems this is not the way to do it.
