I tried GRBL v1.1d together with actual LW3 yesterday. Had to adjust a few lines of code in socketcomms.js (see https://github.com/openhardwarecoza/LaserWeb3/issues/156).
GRBL v1.1d got some nice improvements for laser engraving. In Laser Mode ($32=1) I get smooth movements, no stop-n-go anymore.
Just tested with Adruino Uno, CNC-Shield and Stepper Motors, but no real Engraving. Will test that the next days.
Good work
Thanks! I’ll give it a try tonight. I have been running 1.1 but with the legacy status turned on. The new builds of GRBL won’t fit on the Nano with this turned on so I’m a few builds behind.
@John_Seaton If you don’t need the legacy mode, you could drop a lot of code. Probably it’l fit then on the Nano.
@cprezzi I only needed it for LW, the other programs I use have updated to support the new format. I believe the latest build fits the Nano still with legacy turned off but I’ll confirm that. If it doesn’t then I’ll strip that stuff out to make room
Eventually I’d like to port 1.1 to work on an STM32 nucleo that has the Nano pin out and form factor and then memory won’t be a problem lol.
@John_Seaton LW now supports GRBL v1.1
Will do, thanks!
