I tweaked on my printer a bit… I am not a fan of cooling fans… I am thinking water cooling the hot end is pretty cool…
http://mike.creuzer.com/2013/01/watercooling-my-makergear-prusa-reprap.html
It’s cool that you rigged something up on the cheap. But if you get a better hot end (j-head) it won’t do this either. Makergear hot ends are poo.
I find it curious that this fix is infinitely more complex than a cheap fan. @Mike_Creuzer Are you trying to use 1.75mm filament in a hotend designed for 3mm? That seems like a bad idea to me and possibly the reason you have periodic jams.Both MG and Jhead use a ptfe liner that needs to be sized for the filament you are using, 2mm and 3.5mm I.D. IIRC.
@Brian_Evans the makergear hot ends don’t have a inner PTFE liner. They have this PTFE insert near the top of the cold end (which is absolutely worthless btw), but the entire brass barrel is un-lined. It looks like they actually discontinued that style hot end.
@ThantiK Do not agree with your opinion. My MG hotend has been flawless and I print with 3mm PLA.
@ThantiK Youre right but that upper ptfe insert is a different ID depending on the filament size and so is the brass barrel. My suggestion still stands that if he’s using the larger barrel then that could cause the 1.75mm filament to buckle, cool down, and jam. You did give me an interesting idea to lap or polish the brass barrel ala prusa’s hotend as that might provide better results. My MG hotends have been flawless both 3mm and 1.75 except when I ran cheap ass chinese filament through one of them. Fast heatup, consistent temps (± 0.02 deg), and no jams. The ceramic paste is a little delicate though.
I did this 50% because I can, and 50% because I’ve gone through 3 of those little fans, as many different mounts, and am out of tiny fans.
That whole definition of insanity thing… I wanted to try something different. I’d bought the materials for an aquarium heater project, and this seemed like a fun expansion on it.
I have both 1.75 and 3mm hot ends. Ordered both when I got my MG Prusa Kit a year ago.
I like my MG hot ends. I’ve had no problems with them that aren’t of my own creation except for printing 1.75mm at fine z heights <= 0.1 with slow speeds ~ 30mm/s without that little fan.
@Brian_Evans I would love to see someone polish the inside of the makergear hot ends, I’m also sure they would function a ton better. But seeing as the hot ends look to be discontinued, it’s probably a moot point.
1.75mm ID tubes cannot be polished according to Josef Prusa. He said he looked at offering a 1.75 version of his nozzle, and they just couldn’t get tooling small enough.
@Mike_Creuzer Well that makes sense… Ive only done a couple of prints at .1 and just found that I am too impatient. I could see that the Jhead would be better here.
@ThantiK I doubt theyre discontinued… Rick has had a lot of orders for his M2 that he’s trying to catch up on them so he periodically pulls stock off his site. I bet theres a way to polish the barrel though… Ill have to sometime ask my colleague at the University who teaches Jewelry and see what she says.
I will ask my brother-in-law who’s a jeweler about polishing the inside of the barrels as well.
Why would you want to cool your hot end?
it gets too hot, too high after a while. I just want to cool anything above the fiberglass insulation.
@Brian_Evans it specifically states on the makergear site that it’s discontinued.
I see “Out of stock” http://www.makergear.com/products/groovemounts not “Discontinued”
@Mark_K A general problem with hotends is when the filament starts to soften high up in the barrel and then cools down which will cause a filament jam. You want the filament as cool as possible down to the heat chamber. The jhead uses vents milled in the side of the peek holder while the MG hotend is just shorter.
@ThantiK That would suck if thats the case but when I look at their hotends page it just says out of stock. If @Rick_Pollack discontinued his hotend that would get interesting for all the makergear owners out there.
@Jay_Couture ah, I was looking at the “PEEK Groovemount” - looks like they call the current one a “Hybrid” - my mistake.
I have the long barrel MG hot end, designed for original Mendel. I put some washers down on top of the hot end insulation, but it looks like the barrel in the photo has some extra insulation above the ceramic heater blob. Take that off.
