I used to work for a extruded pipe company back in the day and
I used to work for a extruded pipe company back in the day and we produced two-wall ABS pipe with a foam layer inside the two solid walls. I wonder if we could use the same foam action to fill hollow cavities, either with a dedicated extra head, or double purged from the single head that extruded the walls…
Hell, you could extrude glue (hot glue action?), epoxy, silicone, expanding foam, concrete, plaster of paris in the cavities if you wanted to.
What a great idea. Find the foam that works I’d the tricky bit, slicers can already deal with the second extruder for infill
It was a pelletized plastic that when mixed with ABS pellets under heat made it foam.
@Brook_Drumm ​​​ @Thomas_Sanladerer ​ Have you guys ever came across something like that in your extruding adventures?
