I want to build a very simple rc car as a home project...can anyone
I want to build a very simple rc car as a home project…can anyone help me with the conplete process…??
What are the tools that you have access to? (3d printer, cnc, laser cutter, ect…) What experience do you have with electronics, soldering, ect. ?
@Shachar_Weis i have a little experience with electronics but i dont have any access to 3d printer, cnc or laser cutter…
I just need to know about how to use ICs and the logic…dont need to create the outer structure of the car…just want to create a small very simple rc robot type…
If you want to learn about IC’s and logic I suggest that you go on ebay, and boy some AND, OR NOR NAND and inverters. make a statement: "i have two seats and two belts for the seats. if one of the persons sit in one seat without the belt, the output should be 0/ the car should not start :slight_smile: you will need to make a chart of the 0/1.
did you understand?! I am learning about this on school right now :slight_smile: ask if there is anything you did not understand/need more info :slight_smile: I’ll try to answer :wink:
i know about gates…and or nand nd all…i want to know the logic to how to connect these things to make a working car…
