I want to fit 15mm linear rail (MGN15) to 40mm x 40mm aluminium extrusions that have a 10mm slot. The slot is stepped, however, so the slot width at the mounting face is actually 11.6mm. Since the back of the rail is chamfered, the width of the back of the rail that contacts the extrusion is only 12.5mm. This leaves precious little overlap.
Has anyone done this before? Can you tell me if it works somehow even with such a small overlap?
