I want to make heatbed about 40x40cm by aluminium.
I want to make heatbed about 40x40cm by aluminium. How can i do it? please. Thanks
Better off just buying one
Cut Aluminium to 40x40 and attach a 20x20 Heat bed. Proper insulation and relay interface will speed up the heating process.
Must be perfect flat, buy one.
Buy a milled aluminum plate and attach a custom-made full-size silicone heater with at least 1kW of heating power ->
thanks. but how can i attach relay?
@Quoc_Anh_Le got you covered: http://youtube.com/watch?v=TiEwNf1H_Tc
@Thomas_Sanladerer thanks. i will order heater silicon and ssr. Oh i have another question Can i use heater bed silicon 300x300 with 400x400
Tom is right. You can just get a piece of aluminum cut and a custom heat bed
@Quoc_Anh_Le
wouldn’t recommend it, as even with a relatively thick aluminum plate, you’ll still have a significant temperature dropoff towards the edges.
A 1/4" or 6mm plate has a significant thermal mass. Not sure if temperature fluctuation would be a concern w a silicon heat pad
