I was looking at these 108mm shocks from Integy for my build. These are little more high end but not Blingy. Does anyone feel there is a reason these wont work?
http://www.integy.com/st_prod.html?p_prodid=5977&p_catid=107&ratesortby=New#.VKDKx14AKA
Ask my friend Matthew, aka @RC_Crawler_of_CT … He might know…
No dan but i want it to have nice parts. These shocks should fit. Thanks for the tip AlanRC. Its an expensive option. Im questioning if its better to go low budget or not. What do you guys feel about that?
Richard, I would say that most likely you will have to change the oil in the shocks to meet your setup wants, so to me I would go with a cheap set and get some good shock oil to put in them. You might even be able to buy two or three differ oil weight oils for the same price as the most expensive brand and you’ll sure be able to get the correct setup your wanting…
That is a great suggestion Alan. What do you think about motor. Do i do Reedy brushless or Castle?
Igavr never had ether one so can’t help on that part
