I wonder how retracts for you guys work on your Bowden setup?
I’m using the Bondtech and of course reliable movement of the filament isn’t an issue with that. The E3D v6 on the other hand looks to have problems in my setup with filament beeing printed too slow or with too many retracts.
Depending on the filament I see irregular extrusion: nearly no extrusion first and then a blob of filament coming out of the nozzle. I see this happening with frequent retract following each other or in some smaller prints. This seems to be worse with filament that has quite a big zone of melting going from soft/honey like/gooey to liquid.
Is my 40mm fan probably not good enough to deliver the right airflow? I thought it should be but maybe that could be the problem? I have seen this in the past already with the 30mm fan so I thought it couldn’t be that problem but ineffective cooling is the only thing I could imagine. Or is it just a general problem with this situation in combination with longer retracts like we need the on the bowden setup?
Maybe @Sanjay_Mortimer can add something to the discussion.
