I would like to create a panel for my 3d printer / cnc machine. The panel that one can then install switches and buttons and such. I have been searching but I have found no easy-to-use panel generator that can be used to 3d print. Does someone have a recommendation?
You start with a cube that’s the dimensions of four panel, then punch holes in it the sizes and locations of your controls.
(You then make 5 iterations getting scaling right.)
I know you want to print it but that’s a job for a laser cutter if there ever was one.
I got access to a laser cutter too. My problem is with the plan generation. I am too busy with other things that I would rather drag and drop than fiddling around
DesignSpark could come in handy there. It usually takes just a few minutes to make something like that.
OpenSCAD is a great panel generator
