to dynamically updated the timer to whatever ALERT_TIME is set to.
I am running into an issue when updating ALERT_TIME where the timer will still run out the last of the previous value before updating to the new value.
i.e. -
If I first set ALERT_TIME to 15 seconds (15,000ms) it will call alert() every 15 seconds, no problem.
However, if I then set ALERT_TIME to 30 seconds approximately 10 seconds after alert() was last called, then alert() will not be called again for 35 seconds, after which point the timer will trigger every 30 seconds without issue.
In short, it seems to be adding the remaining value to the new value on the first pass.
The reverse is true when moving from a longer to a shorter timer value.
If I first set ALERT_TIME to 30 seconds it will call alert() every 30 seconds, no problem.
However, if I then set ALERT_TIME to 15 seconds approximately 20 seconds after alert() was last called, then alert() will be called again in 10 seconds, after which point the timer will trigger every 15 seconds without issue.
In this case, it seems to be allowing the previous timer value to run out before using the new value.
Is there a way to clear a running timer before setting a new value in the case above?
I also found this example over here which uses this method:
It’s not clear to me whether the example you shared or the one I linked above actually addresses the issue I’m seeing of timers not clearing existing values.
@Operator Both the sketches you linked to will have the same issue you’re experiencing where after you change the timer length it doesn’t take effect until the next go around.
I think using reset() is what you’re looking for.
I think I’ve found a functional but inelegant solution which clears the “initial” timer. It uses the trigger() method to force things through. I’m sure there are better ways of going about it.
Note: I’m using CEveryNSeconds instead of CEveryNMillis.
Hi matt, apologies for the slow reply. Your response seems to have been marked as spam initially so I was not notified of it. I’ve restored the comment now though so it’s visible.
This is an interesting approach and I’ll give it a go to see if I can make it work and reply here.
Very much appreciated for the response in any case!
I got this resolved and it now seems terribly obvious after the fact.
I ended up declaring CEveryNMillis alertTimer(ALERT_TIME) globally so that in my loop() I could call:
if(alertTimer) {
alertTimer.reset();
alert();
and in my function that receives my alert period over UART I could do something like:
I needed to call reset() both when the timer is triggered and when a new ALERT_TIME is set to avoid the issue which I obviously couldn’t do when alertTimer had only local scope.
