I’d like to use “Feedrate X” feature to change the feed rate during a job, but usually there are thousands of lines already sent. Is there a way to reduce the buffer size? I’m using an Inventables X-Carve with Arduino gShield controller, and both Chilipepper and SPJS are running on a Windows XP laptop.
Okay, I got SPJS 1.85 built and working. So it looks like I can type the fro command into SPJS console at any time? Would you recommend doing a freehold before overriding the feedrate and then cycle start after?
