If it possible to add a button “Clear” in GCode Widget to remove current gcode in List and in localStorage? Cuz i use a workaround now, if i add gcode from eagle import and add after then the gcode z correction from AutoProbe, then i get double corrections on every z gcode. If i remove the gcode with an empty gcode file, then eagle import, send to gcode buffer´, send autoprobe data … it works. Hope you understand me
Well, what if you just load the ChiliPeppr logo gcode as your form of clearing? That’s available from the top left right near the workspace label under the menu.
Nice idea, i’ll try this
