If you ever wonder what should be the first object to print in the
If you ever wonder what should be the first object to print in the RepRap you finished making, I have the answer, Spare parts
Well, before that, you should print a minimug ( http://reprap.org/wiki/Minimug ) for a toast to your completed printer!
Good idea. I haven’t thought about that. :slight_smile:
I only got to about half height after several attempts on my minimug (I used the teardrop reprap-logo-shaped one though), so I toasted it with a half minimug.
(Turns out the printrbot wood extruder with 1.75 mm filament does not mix well with retraction unmodified, especially not default 3 mm retraction — the hole between drive and hot end is 3mm filament sized and with the retractions the filament would buckle in there during the refeeding. A small piece of PTFE Bowden tube to make the hole smaller cures all ills.)
