If you only knew how much @Mark_Kriegsman and I make our eyes bleed for you
Haha… Staring at LEDs all evening… It must be burning man time.
Nope, not even staring at leds. Staring at asm code and asm documentation and trying to figure out how to squeeze something into the smallest number of clock cycles possible.
Aha, just as eye bleeding. Keep up the good work man!
Love ya, brother!
Visine… Get’s 1/3 of the RGB out…
Thanks for everything you guys do !
Every so often I like to play around with Verilog, but cannot imagine what you dudes go through. Every single f’ing clock cycle on many different platforms. Crikey! Much grovelling on our part, to be sure. . .
You are my heroes.
Y’all showing off anything on the playa this year?
I’m not - took the summer off from building anything (though starting to pick up major library features and may end up building something by the end of summer in the Bay Area)
I’ll be bringing a piece we’re calling Zen Ball. It’ll be a 1meter wide table with an intricate pattern in wood, with the gaps in the pattern all lit up by LEDs. On the table top will be 2 large steel balls that’ll rotate around the table top triggered by activity picked up by two EEG headsets. It’ll be a kind of variant of the Mind Ball games that did the rounds a couple of years back, but with a lot more LEDs!
I’ll post some pictures once the full stack is up and running, hopefully next weekend.
I hope you’re at least also bleeding green and blue so you get all colors.
(Can you just imagine rainbow tears?!)
Thank you @Daniel_Garcia and @Mark_Kriegsman for all your work and support.
You @Daniel_Garcia and @Mark_Kriegsman are my inspiration. Thanks for your work and support.
I am constantly amazed at what talented people can do with code – it’s like painting masterpieces with a keyboard… but harder. An artist can always claim any mistakes are part of the picture – not so the hard-working coder. I’d still be working with shift registers and monochrome LEDs if wasn’t for you guys. Thanks!
@Daniel_Garcia Hello Daniel, can I get in touch with you privately?
@Juergen_Bruegl sent you a hangout request, alternatively you can email me at gmail using danielgarcia@
