I’m building an ORD Bot 3D printer and I’ve decided on the J Head hot end and am trying to decide on the extruder. I was wondering what are some of the better designs to consider. Thanks
Check out the SeeMeCNC kit. Its direct drive and all injection molded. Works great.
Thanks for the suggestion Brian.
I’ve had that one recommended to me too (by @Loren_Brandenburg I think). May be worth getting the Bowden fittings with it if you want to keep your carriage weight low (allowing for faster print speeds).
Thanks guys, think I’ll go with the one from seemecnc.
