I'm converting my K40 to an Azteeg X5 mini v3 and I am having
I’m converting my K40 to an Azteeg X5 mini v3 and I am having a little trouble with the wiring for the laser power and control from the azteeg to the psu. Could anyone give me a hand on the wiring diagrams?
@kyle_clement Do you have a Level shifter?
Here is a schematic of my smoothie conversion which may help. Note I am not using a level shifter, pwm to L on laser supply.
https://plus.google.com/113684285877323403487/posts/66DXUBsGqUK
@donkjr have you fired your laser yet? Interested in the result of not using the shifter
@Ariel_Yahni_UniKpty not yet, but there are a number of folks on here who have this config working with the right config file. Days away from my own verification.
mmm Original smoothie without level shifter? not sure about that but maybe im wrong. What im sure is the one cable setup, L from the PSU
Actually although I have not tested it with the smoothie I have with a pwm circuit directly into “L” with no smoothie.
@Ariel_Yahni_UniKpty ​ not sure I understand your
one cable with L meaning. I have one cable to L from smoothie open drain, no other cables.
i haven’t ordered the level shifter yet but was planning to
