Im getting a “DIO26_WPORT was not declared in this scope” error when I upload my sketch. I have no idea why, I never changed any code. It even does this if I revert back to the original firmware. Repetier firmware btw… Any ideas?
Have you selected the correct motherboard? Double-check all your settings. Make sure you haven’t accidentally commented (or un-commented!) anything. Double-check that in the arduino software you have the correct port and board selected. Also, for shits - try Marlin/Sprinter, see if those upload correctly.
Hi Matthew! Did you get the problem with DIO26_wport solved out?
I’m facing the same error message.
I do believe I did. I moved recently and haven’t been able to break the printer out of the box
