I’m having a hard time with something that I’m very sure is easy.
I’m putting some neopixel strips on my quadcopter.
I want to run them both from the same arduino
I’ve got them setup on Pin A4, A5. I can make one or the other work, I just can’t seem to get them both to work together.
My original intent was to just do a larson scanner on both of them.
I’d like to do just blue on one, Red on the other one. It doesn’t seem like a hard thing, but I’m missing something somewhere.
I really don’t even need it to be a scanner. If I could use some of the different animations that could be used with a single color, that would be great too.
Would anyone be able to point me in the right direction for a tutorial for this? Or have time to try to point me in the right direction?
Can you post the code you’ve been trying to get working to pastebin? I’m sure we can help get them both running the Larson scanner in what ever colors you’d like.
@Sam_Smock Ah! Well if you do try it using FastLED give another ping.
BTW, when I first tried adressable LEDs using the Adafruit library I used 4 pins with 4 strips so multiple pins should work, but I wasn’t using Neopixels.
