I’m having a issue cutting through 2MM acrylic now.
I have 2 different types, 1 is a mirror acrylic with some clear paper on top and other is black with the brown paper.
Mirror acrylic - No issues cuts through without paper or with paper - no burns no issues
Black acrylic - without paper it will cut through but leave residue all over it(Im cutting many small pieces ) With paper its burning the paper and not cutting through.
What I feel is that once a area starts to heat up it just starts burning it, if I cut a line straight through the acrylic it will cut no problem. But if I’m dong several shapes side by side (.1inch gap) it won’t cutter the first piece
Also how do I clean slime build up inside? I heard you can use RV coolant and just keep it sealed. I’m doing this from inside my college apt. Literally need this working because I started a business that requires this and it helps me pay for college!
Any ideas for hooking p exhaust to bathroom vent?
Im in a college apt on first floor and probably shouldn’t have a laser cutter here. Im at front of apt so people are going to see or smell it cause its obviously going out my window
