I’m having a strange problem while calibrating my printer. I’m printing a square with a hole in it.
The square is 0.5mm over size while the hole is 0.5mm under size.
I’ve calibrated the E steps and the object doesnt look overfilled or squashed.
Any ideas?
I fully appreciate that but my old mendel i2 is much better than +/- 0.5mm.
I’m using a 0.35mm J-head. I’ve tried slic3r and Cura with exactly the same results.
Using slic3r i tried to change the perimeter extrusion width and I couldn’t get the dimensions accurate without losing quality.
I am assuming that this is a hardware issue?
Can you start printing the hole OD and then complete the square perimeter last?
@Temujin_Kuechle I don’t really see how that would help. its 0.5mm out using a 0.35mm nozzle.
What are you thinking?
I’d say youve a miss match in your software regarding extrusion to wall thickness
@Nigel_Dickinson Do you mean the perimeter extrusion thickness in the slicing software?
I meant that sometimes there might be an advantage to building from the hole outwards if the hole is critical. However, it’s just an out of the box idea, a suggestion to try for a different result. It might just be a software issue related to wiggle or extruded diameter. I use an SLA printer in my workflow and its also not that exact, as it can be .03mm off on the x and y axis. Normally, I offset my parts .05 for fit.
@Daniel_Wood yes is it a multiple of the nozzle size. So 0.35,0.7 etc for your wall thickness
