I'm having tremendous trouble importing my DXFs.
I’m having tremendous trouble importing my DXFs. They’re exported from Illustrator, but I’ve loaded them in both QCad and DraftSight and saved as R12 ASCII DXFs.
I finally had the sense to load the web version of LW so I could look at the console (how do you do that from the desktop version, btw?) and I see the following error:
Unsupported dxf entity: INSERT:BLOCK_2
I’ve saved it in about 15 dxf versions (all from DraftSight) up to R14 and they all give the same error. Any ideas?
Open your dxf file with inkscape, check the drawing and export to dxf.
Then try the dxf saved from inkscape with LW.
I had problems with my files and this was a good solution for me.
I believe you can also open the dxf in inkscape and export to svg as well. Svg’s import no problem.
Please open an issue on github attaching file. In the meantime, you could just use AI svg to load (as you mentioned AI). I’ve exported a bunch of dxf from F360 lately and had no problem thought.
Thanks. I tried DXFs from Inkscape but no joy. SVGs don’t work either - different error though: ““TypeError: Cannot read property ‘2’ of null””. Null in this case is the ViewBox property, which the Inkscape SVG save (in both Inkscape and Plain styles) doesn’t seem to provide.
