I’m in need of a bit of assistance, i’m messing around with a HEAVILY modified Demoreel100 based sketch that I’m working on integrating a button into, this does exactly what I want it to do for the most part, right now it changes patterns every 15 seconds like I want it to, it changes patterns with the press of the button, and it stores gCurrentPatternNumber to the eeprom when I hold the button for 1 second just like it should. I’m trying to get it to “ignore” the nextPattern(); loop every 15 seconds but only when there wasn’t a “longpress” event. I basically want it to cycle through my patterns normally every 15 seconds and also advance to the next pattern when I press the button, then “lock” the current pattern that it’s on when I press and hold the button for 1 second. It’s probably as simple as an “If/Else” statement but I’m having trouble figuring out where to put it and what it needs to do. Can anyone give me some insight? Any help is greatly appreciated.
void loop()
gPatternsgCurrentPatternNumber; // Call the current pattern function once, updating the ‘leds’ array
readbutton();
FastLED.show(); // send the ‘leds’ array out to the actual LED strip
// do some periodic updates
EVERY_N_MILLISECONDS( 15 ) { gHue++; } // slowly cycle the “base color” through the rainbow
EVERY_N_SECONDS( 15 ) { nextPattern();} // change patterns every N seconds
} //loop()
void nextPattern()
// add one to the current pattern number, and wrap around at the end
gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE( gPatterns);
Serial.println(gCurrentPatternNumber);
}//nextPattern()
void readbutton() { // Read the button and increase the mode.
myBtn.read();
if(myBtn.wasReleased()) {
if (longpress==1) {
EEPROM.write(eepaddress, gCurrentPatternNumber);
Serial.print("Writing: ");
} else {
gCurrentPatternNumber = gCurrentPatternNumber > maxMode-1 ? 0 : gCurrentPatternNumber+1; // Reset to 0 only during a mode change.
longpress = 0;
if(myBtn.pressedFor(1000)) {
longpress = 1;
}//readbutton()
