I'm planning a new project driving 8 strings of 240,
I’m planning a new project driving 8 strings of 240, WS2812B dots for a total of 960 dots. I’m going to be using a teensy3.5. I’d like tips for how to hook this up. I understand the library has a way to optimize for parallel outputs.
I’m sorry Chuck but i don’t think that the teensy 3.5 is supported yet. As far as I know the library only supports Teensys up to and including 3.2
OK, I can use 3.2. Same question applies.
I’d consider using one of these if you only want to drive eight strings. There’s loads of information on the PJRC site.
https://www.pjrc.com/store/octo28_adaptor.html
Looks good. The real tip in here is this https://www.pjrc.com/teensy/td_libs_OctoWS2811.html
OctoWS2811 definitely works with Teensy 3.5 & 3.6. The new boards are longer, so extra tall pins (or pins+sockets) are needed to position it higher so it clears those 2 RJ45 jacks. But FastLED might not fully support the new boards yet, so if you need the great drawing/rendering features of FastLED, probably safest to go with the older board.
The real tip is to combine the OctoWS2811 adapter with FastLED, see below :wink:
