Im running a Delta with smoothieware.
Im running a Delta with smoothieware. Has anyone experienced their sliced code being inversed?, For instance, ill design a model with writing on it and it slices perfectly, but when printed it will be inversed. Like a mirror image. Any tips would be appreciated.
Sounds like you have two of the towers inverted. need to swap motor leads and any tower offsets you have applied to the limit switches so they stay with that tower.
Hrmm sounds plausible, ill try that when i get more time tonite. Thanks for the quick reply.
@Eclsnowman is spot on with this one. Usually it’s the X/Y carriages/endstops that are swapped out.
When you swap the towers, be sure to swap the end stops too.
Yep, @Eclsnowman ​ was right on the money. To summarize, i swapped the x/y end stops, offsets, and wiring pins in the firmware. Easier for my particular build. Everything seems to be running as expected now. Thanks again folks!
