I'm sure this is probably p simple, but I'm on a tight timeline.
I’m sure this is probably p simple, but I’m on a tight timeline. If someone could point me in the right direction for this:
Has anyone made a sketch that has LED strips cycle between gradients every time a digital input is activated (like a button or potentiometer or photocell or timer used as digital input)?
(as in, when toggle activated strip showing gradientn+1 [out of gradient1, gradient2, gradient3])
If possible, I am going to try to also make the color palettes cycle across the different strips, but that part should be easier.
(as in, when strip connected to pin 3 is showing gradient1, pin 4 is showing gradient2, etc)
this is the project btw
Should I use the loop code from demoreel100?
How do I get it to work with inputs?
Here’s a modified version of Demoreel100 that uses a button to change patterns.
Cool looking project.
THANK YOU SO MUCH, PAL FRIEND!
It’s called space kraken~
