I'm thinking of converting a to become a style .
I’m thinking of converting a #Prusa #i3 to become a #gantry style #3D #printer. This means the print bed stays #stationary and the Y axis movement is made using the gantry moving back and forth.
Sharing help request here for broader reach (apologies for the dupe on RepRap forum) Need advice & help building a RepRap gantry style printer
I would appreciate any advice & suggestions to make a gantry printer from reprap parts.
I’d like to add this style to the RepRap community models later once the printer is working with a proven design.
The first thing I need to do is build a skeleton box to mount the rails and stepper motor for the gantry’s Y-axis stepper. I’ll be reusing the existing Z mechanism with the gantry so just need to bolt it on to the moving gantry’s Y axis.
Second, I’m thinking the wiring doesn’t need to be modified (I take the Y-axis stepper along with its wire and mount on the gantry).
Any advice? Avoiding rod sag and backlash? Gotchas? Any other things I missed? Has anybody done this before, just so I can have camaraderie :slight_smile: and/or can help/mentor me?
The reason I’m doing this is to get a larger printbed (say 500mm x 500mm x the current Z height), with low cost for the conversion so others can do the same), and for others to build themselves from parts.
I also want to use this as a paste extruder later using Rich’s paste extruder design on Thingieverse (cookies, cake icing, chocolate, clay, etc.). I plan to print pretty small height but large diameter/rectangular stuff, put a cooked iced cake on the bed and print a design (“Happy Birth Day Mom!”).
Having a larger bed would also help mounting a larger extruder, opening up a possibility of using 4 extruders (Red, Green, Blue, Black) to print in varying color shades (sort of an like inkjet printer with really coarse resolution).
Many Thanks in Advance, Caesar.
Why convert the i3? You will basically scrap most the machine. Surely its easier to start again and give the i3 to a buddy?
I want the RepRap community to have an option for a gantry style printer. Converting one hopefully costs less.
It would help if you could elaborate on scrapping most of the machine?
The frame is a big part of the machine, theoretically the rails would be a different size in a gantry based machine. The plastic bits that hold the vitamins will need to be redesigned.
Yeah you’re right about that. Reusable: stepper motors, couplings, bolts & nuts, rods if I keep the size the same, belts might need additional length splicing, electronics, power supply. There’s really no frame to speak of for Prusa.
