I'm trying to figure out how to control my cold end fan from my
I’m trying to figure out how to control my cold end fan from my ramps board. I’m using Marlin, and it looks like it supports this, but I can’t find any good tutorial on how to wire it up. Has anybody done this?
https://github.com/ErikZalm/Marlin/pull/390
I put that in marlin quite a while ago…
I wrote a bit at the bottom of this post about it too
http://captain-slow.dk/2012/11/22/attten-858d-smd-rework-station/
And here is something about how to connect a fan to a pin on an arduino http://captain-slow.dk/2011/10/28/sprinter-m42/
Nice idea
Thanks @Michael_Andresen ! Turns out all I had to do was wire up my fan to the D9 terminal, and the fan gets controlled by the M106 & M107 commands automatically from my GCode output from Slic3r. I love it when it’s that simple! All the hard work was already figured out. Thanks again!
Those will only turn the fan on when it is told to do so though, and it might turn on way later than you might want… the stuff I linked to turns it on and off no matter what the code say
Yeah, most newer releases of firmware will turn it on above a set/actual temp, so no chance of forgetting.
