I’m trying to print a student’s project that is basically a circular disc 11cm dia. and 4cm tall (Ultimaker orig). As it’s printing the bottom layer it reaches a point where no filament is being extruded. This is my first print where the bottom layer has so much surface area and it seems as though it is trying to lay down the filament faster than the filament is being fed. In fact when I unhook the feeder, the filament is no longer connected to the nozzle.
I see in Cura where I can adjust various speeds, but I’m not sure which one I need to slow down (assuming that the speed is the problem)
Advice is appreciated.
