I’m up and running with my new board and LaserWeb3. Yay!
Question, what setting either in the smoothie config or LaserWeb controls the feed rate when it’s not burning? Right now it actually burns faster than it transitions across white space.
In smoothie config the first 2 options deal with feed rate and seek rate. Increase both a little to about 6000. If jog is slow the on the interface change the default 30 to something higher again I like 100mms. Then in the settings there another option for travel moves under the label
Yay indeed.
Huge kudos to @raykholo for all his help. I wouldn’t be half as far along without his guidance and answering my questions.
Well, it’s my board, which makes your success my responsibility. Now go test the living daylights out of it please.
Will do. I have to relearn how to use everything since all of the settings I used to use in CorelLaser are no good anymore. Plus learn lots of new capabilities that this opens up.
Mine was doing the same. I increased the default_feed_rate & default_seek_rate to 27000 (since I use 500/400 white/black, which equates to 30000/24000 mm/min, so the 27k is a good balance between the 2).
