I’m using an LED Strip that uses a few TM1803 chips to drive the RGB LEDs. I can control the intensity of the light but not the hue. The color always stays red. I tried defining the color using the RGB as well as the HSV but to no effect. I tried searching but have not found a solution to this problem. Does anybody have any suggestions? Would this be an appropriate problem to post to the Github Issues? If so, how can I become a contributor to the project?
Red usually means you are supplying too little power to the led strip.
That might be it. I was supplying only 5V to a 12V strip. I’ll try that out and come back if there is still a problem. Thank you!
“There’s your problem…”
