I'm using standard ramps 1.4 on Delta configuration.
I’m using standard ramps 1.4 on Delta configuration. It seems to connect to the printer successfully but if I touch any keys or any commands IT disconnects. Then it’s difficult to connect again you usually disconnect the USB cable.
