I’m very lucky to have access to these machines!
Originally shared by Andrew Bougie
Curious about what’s involved in part finishing and cleanup on professional 3d printers? Check out the latest video I made for work!
#3dprinting #3dsystems
Thanks for sharing this. That’s a lot more post processing than I do! Then again, those parts probably are higher resolution than I print.
@Carlton_Dodd Glad you liked it! The cleanup involved definitely depends on the part you are printing and the type of finish you are looking for.
The objects in my video were printed in XHD mode(16 micron layer thickness) and have internal moving gears that require the use of an ultrasonic cleaner to remove residual wax. Simple models without moving parts and without too many holes can just be placed in the oven.
