I’m working on a new widget that I created from scratch, I copied all the standard code from Eagle Widget, everything is working fine except when I try to use Clipper Library, the widget throws the following error:
Uncaught ReferenceError: ClipperLib is not defined
In (requirejs.config) I have the following line within paths:{}:
Clipper: ‘//http://i2dcui.appspot.com/js/clipper/clipper_unminified’
Is this enough? do I need to add the reference somewhere else?
