I'm working with Prusa Slic3r Edition, It is truly fantastic.. However...
I’m working with Prusa Slic3r Edition, It is truly fantastic…
However…
Does anyone know where the settings are kept for the filament change? I believe it is done in post processing, I just can’t find it. I’d like remove the long retracts and filament insert, the print head I am working with does not need them. I’m currently modifying the gcode and it’s a pain.
I perused the settings/ reference strings in source briefly, and I believe them to be hardcoded. I’m talking about the prime tower. Like, that’s in the source code, not in the print settings. I think you can change the length of the purge though.
Thanks. That’s what I came up with too. I was hoping to find where it was hard coded, but there are so many files to go through. I was hoping someone already knew.
@raykholo did you ask for an adopt-a-bot? Can’t remember. If so write me so I can get your address and send payment info
Brook@printrbot…
@Brook_Drumm Yep, just emailed you.
