Importing DFX into CorrelDraw (X7)
Hi all. I have a DFX file using three layers (engrave, halfway cut and full cut). If I import this file into RDWorks, I get three seperate layers, so I think the Dfx file is Ok. RDWorks does not work with my k40, so I need to use correldraw. If I import the file into correldraw, everyting is put into one big layer. The objects have a different color for the layer (red, blue and black).
So now I have to manually create three layers (red blue and black) and move the objects from the big layer into the new layers.
Question one:
Is there a way to import a Dfx in correldraw with the correct layers in place
Question two:
If not one, is there a way to sort a layer on color. Now, they appear in random order (creation order?) witch make moving them to a separate layer a troublesome task.
Or select objects with the same color?
