Improved XYZ map and completed prototype stand for the ULTiM8x8 cube.
I reworked the map, switching from 8x8x8 to 10x10x10, which reduces the seams between panels. The old map, for example, treated all LEDs on one panel as X==0, and the first column of LEDS in the adjacent panel as X==0. The new map treats that same column of LEDs as X==1 instead.
The next stand prototype will rotate and have a shorter cylindrical base. I need to work on my 3D printer, I’m getting bad under-extrusion gaps and seams. Might be time for a new PTFE tube and/or nozzle. Been thinking about upgrading to a Bondtech extruder and Micro Swiss all metal hotend.
ULTiM8x8: http://wyolum.com/ultim8x8/
Source Code: https://github.com/jasoncoon/esp8266-fastled-webserver/tree/ultim8x8-cube
Oooh going from 8x8 to 10x10 was a nice tweak. :slight_smile:
This is awesome! These kimd of 3D displays could be ven better with a gyro/accel inside or some kind of motion tracking. You could create a 3d image and rednder it in slices on the surface of the cube depending on where you move. This idea wasnt mine, a bunch of people sugested it to me for a spherical device i made like this,but it could work on any shape
@Jason_Coon ​ bruh, when i grow up i wanna be just like you :slight_smile:
@Leon_Yuhanov that would be very nice , the problem to be solved on such implementation I think , is to capture the viewer location in respect to the cube , as all projections will need that information to create a real 3D sensation …
It seems amazing but I can not see it, error 404
@Jesus_Vicente strange, works fine here, tried it out on multiple computers.
you are right!! It works Thanks
It works for me lol
Wow looks better than my version! https://jonasvorwerk.nl/events/inkijk-galerie/
