In celebration of the 2.0 release, I give you meteorShower! @Thomas_Eldredge originally posted his ideas to his site, here is a variation to a small snippet of his code.
http://pastebin.com/FPnB9tss
Had a chance to test this out, one of my favs right now. Probably going to tweak some ideas based of it and see if it’ll work.
Thanks, this was one of my first real successful coding attempts. It may be a bit clumsy and scattered, but it should help those looking for a way to randomize things in existing animations that you may have already written. Good luck, and share your results!
I love this piece!! Not sure how it works but it’s very cool.
I admit, the code is a bit ‘dirty’ looking. When I was learning about coding, I would take other peoples code and start changing this, adding that, just to see what I got. This is one of those experiments. I am SURE that you could get this effect with different code, but why change something that works right?
I have another piece here now (I called it “Glam”) but I can’t get it to go. I am looking for some info on the data pin. I am learning very slowly, one day it will “click”
I figured it out! I used some of Kreigman’s code for the setup.
