in configs, I see from bitbucket that the default config now uses “sensor_E” instead of “temp_chart_E”. I tried changing my config to use sensor_E but all I get is the temp reading is off. and when I use temp_chart_E, it gives me temperature reading.
I didn’t see any warning. Everything was fresh install from kamikaze 2.0.8 flash. The only thing I carried over from version 1 was my printer config which still has temp_chart_E…
