In my 3d printing quest,
In my 3d printing quest, I came across this extruder and wanted to know if anyone is using it or one like it. I had a similar idea, but hay what is Thingiverse for!! I would be using it Bowden.
Thoughts ???
http://www.thingiverse.com/thing:1247952
The belt is probably going to wear fairly fast, but I don’t know if it’ll wear fast enough to actually cause any problems.
How will you adjust tension ???
Not sure but here is a YouTube video, https://www.youtube.com/watch?v=Cd8yOYo9mJU, and a page about it https://www.3dhubs.com/talk/thread/new-type-cold-end-vaeder-v-struder.
See the V-struder thread of the Reprap forum: http://forums.reprap.org/read.php?1,610779
Belt drive is a great idea, like @Jon_Stern ​ says check out the v-struder for some other ideas.
I tried but did not seem to get the appropriate grip out of it. Hard to adjust without swapping different length belt, and in/out direction is a little confusing. I want it to work though…
You need to get at least 90 degrees or 120 degrees of force on the filament from the drive wheels. @Tim_Hatch ​ do you have any pics of yours?
