In my never ending quest to find the ultimate way to secure abs to
In my never ending quest to find the ultimate way to secure abs to the print bed… I’m thinking I may have found an answer.
A polyethersulfone sheet. It has very similar properties to PEI sheets but seems to hold ABS a lot better. It has a shinny side and a matte finish side… You print on the matte side. I just applied like PEI sheet with 3M-468MP. I’ve only done a few test runs but so far so good! I will try some larger longer prints in the next few days and report back
http://www.stratasys.com/~/media/Main/Files/SDS/ULTEM_Build_Sheet/SDS_FDM-Foundation-Sheet_High-Temperature-US.pdf?la=en
Ultem is pei.
this is what is used when printing ultem in a fortus
I was on the same quest until I built a chamber for my printer. Heated chamber solved all ABS warp issues.
Check out http://www.fleks3d.com/
Ah, @Loren_Brandenburg I stand corrected. This is PES (Polyethersulfone) not PEI (Polyetherimide) That’s interesting, I didn’t know that PEI (in resin form) was a popular SLA material.
Ran a 12 hour… 8 inch diameter abs part last night with no lift :wink: part still failed as it had some layer separation half way up but at least it stuck to the bed
