In trying to mill an autolevelled board at a low feed rate, to a depth of 0.05mm I have now broken eight supposedly strong (carbide) drill bits. All are fluted rather than V shaped.
The board is fr2 so soft.
No spindle speed control so going at full tilt of 12k.
Whilst I think the autolevel is not working properly due to inadequately straight leadscrews it is clear that I’m probably using bad quality bits (although they were 4£ each).
Is anyone aware of good quality end mills in Europe? I’m looking for 0.2 and 0.3mm primarily (many fine pitch ICs)
I accidentally used drill bits before and learned the hard lesson that some ebay sellers list drill bits as end mills. The drill bits would crack instantly.
Hmm. They do look like end mills. I’ve only broken 0.3mm ones when trying to auto-level and couldn’t get enough voltage through the tiny tips so gave up. I do run my jobs pretty high up for a first pass so I never get high spots on the FR4 that are so deep I’d break the tiny end mills. I’ve mostly used Kyocera Tools end mills. http://stores.ebay.com/CARBIDE-PLUS/2-FLUTE-MICRO-ENDMILLS-/_i.html?_fsub=10
Oh, I just cheat and set my Z zero like 0.1mm too high from the true Z zero. Then run the job. Then go down on Z 0.1mm to get back to true zero and then run 2nd time.
