In which file the driver routines for ws2811 is present
Look at “chipsets.h”. You’ll see that WS2811Controller is a subclass of ClocklessController. ClocklessController is architecture-specifc, so depends on the architecture you’re interested in. Look in the platforms directory for header files with the name “clockless”.
Thanks for your reply
Iam new to arduino
Using Arduino uno with ATmega328 & WS2811 I want to drive 2000 led.
Since memory is low, I have planned to drive 400 leds and calling this 400 led array for 5 times inside the driver part
Suggest me where to update
That’s going to be difficult to do because the avr clockless output is heavily macro’d hand timed asm code - look in the files in platforms/avr - but I don’t know that what you want to do will be easy to do (and keep the timing tolerances).
